1997 Ford Thunderbird 1997 ford thunderbird cooling not wor
1997 FORD THUNDERBIRD
100,000 MILES • 6 CYL • 2WD • AUTOMATIC
PEEWEE31363
MEMBER
1 POST
FOLLOW
replaced thermostat coolant temperature sensor for gauge temperature sensor for fan and constant control module
Dec 20, 2009 at 11:35 AM
HMAC300
CERTIFIED EXPERT
if your car is overheating , get it hot then shut the engine off and go outside and check your raidator for cool spots. If it has cool spots the radiator is bad. It should be the same tempreature all over. You really haven't said what the problem is, be more descriptive next time. Make sure the radiator cap is good as well as those are often overlooked.
