1996 Ford Thunderbird torque specs for an intake manifold
1996 FORD THUNDERBIRD
ISLANDER69X
Engine Mechanical problem
1996 Ford Thunderbird 6 cyl Automatic
Hi, my name is christian. I am looking to find out what the torque specifications for an intake manifold on a 1996 ford thunderbird are? If you know the answer, please get back to me asap. If you do not, please let me know so i can search elsewhere
May 18, 2010 at 3:42 PM
Hi: THey need to be torqued to between 15 and 22 ft lbs. Here is the sequence to tighten them in:
https://www.2carpros.com/forum/automotive_pictures/249084_4_1.jpg
Let me know if this helps. Joe
May 19, 2010 at 11:21 PM
MANTICAMDAMAN
  • 18 POSTS
I recomend replacing lower intake bolts as the heads like to break leaving the bolt in your car. If you cannot make out specs due to scanned image email me at [email protected] I have the entire ford manual for this car and have taken the whole thing apart many times
https://www.2carpros.com/forum/automotive_pictures/530778_scan0009_2.jpg
https://www.2carpros.com/forum/automotive_pictures/530778_scan0007_2.jpg
May 23, 2010 at 9:49 PM
MANTICAMDAMAN
  • 18 POSTS
teh lower bolts are alos 5 N-m or 44.48 lb per inch
May 23, 2010 at 9:51 PM
