1996 Ford Thunderbird OIL PUMP
1996 FORD THUNDERBIRD
150,000 MILES • 6 CYL • 2WD • AUTOMATIC
BOBBY TALFORD
hOW DO YOU REMOVE OIL PUMP
Nov 4, 2010 at 11:48 AM
You need to remove the oil pan first. Once removed, the pump is bolted on the rear main.
Nov 5, 2010 at 11:24 AM
BOBBY TALFORD
Would i have to pull out the engine
Nov 5, 2010 at 11:31 AM
If you are lucky, no. You may be able to lift it enough high enough by just unbolting the motor mounts.
Nov 5, 2010 at 12:01 PM
