1996 Ford Thunderbird High idle problem on going
1996 FORD THUNDERBIRD
210,000 MILES • 6 CYL • 2WD • AUTOMATIC
MYFORDS
#1: Dose the cannister purge valve stay open or closed while engine is running.
#2: Purge valve is operating correctly when i done a bench test on.
#3: If it is supposed to stay open while running,if it does not stay open will that cause the the high idle problem.
May 10, 2010 at 1:02 PM
If it is closed, it shouldn't cause a high idle. Have you checked for vacuum leaks? Also, has the throttle position sensor been checked?
May 14, 2010 at 10:12 AM
