1996 Ford Thunderbird battery
1996 FORD THUNDERBIRD
MSTOUP
Electrical problem
1996 Ford Thunderbird V8 Two Wheel Drive Automatic
I have been having a real problem with my car. I really need help to figure this out. The issue that it is having is keeping the battery charged. Last night I was only driving about 16 miles and before I got home the car died. I have put 4 different alternators on the car and had the battery tested several times. This morning I put in a new alternator and had the battery tested. I also replaced the plug that goes into the regulator and had the wire for the voltage redone so that it connects properly. I also checked the fuses and they all seem good. My serpentine belt is bad, but I was told that it would not cause the car to do this. What else could be causing this problem?
Aug 15, 2009 at 3:20 PM
If both fuses the mega 175amp and no. 11 15amp are okay and you got power going to the alternator at the black and orange and also the yellow and white-the problem is in between the alty and the ignition switch thru the charge indiactor which is the red and light green. See diagram-Good luck
https://www.2carpros.com/forum/automotive_pictures/12900_ford_charge_1.jpg
Aug 15, 2009 at 3:53 PM
