1996 Ford Thunderbird BAD BRAKE LINES(CENTER OF THE CAR,MET
1996 FORD THUNDERBIRD
135,000 MILES • V8 • 2WD • AUTOMATIC
IOJOE
DO I HAVE TO CHANGE THE WHOLE SET OF BRAKE LINES,FRONT TO BACK OR CAN I CHANGE THE BAD SECTION WITH NEW PIECES BRAKE LINE AND COMPRESSION FITTINGS?
May 20, 2010 at 2:32 PM
With steel lines, I recommend you replace the entire line and not splice them together. As we all know, splices can leak and that isn't a component you want to have trouble with.
May 24, 2010 at 10:33 AM
