1995 Ford Thunderbird turning wheel causes squeeking or squ
1995 FORD THUNDERBIRD
112,000 MILES • V8 • AWD • AUTOMATIC
NETSRIK18
  • 5 POSTS
car began making noises when i turn the steering wheel progressively getting worse does any body know what this might be
Sep 21, 2009 at 4:43 PM
IMPALASS
  • 3,112 POSTS
Hello –
To better assist you is your model the LX or Super Coupe and what is your engine size in liter.
Also, need a little more info….when you are turning the wheel are you saying the noise is coming from the tires or from the engine?
Sep 21, 2009 at 8:44 PM
NETSRIK18
  • 5 POSTS
It is an LX do not know what size engine is, I do not believe the noise is coming from engine it is in the front end though I was thinking it might be bearings needing greased or the belt when you start to drive it you can't really hear anything till you turn the steering wheel and it seems to me the noise almost sounds like creeky joints everybody describes things different,do cars need greased at times? other than that sound it driving fine. if it were tie rods would it be making such a sound? i also believe it needs a front wheel alignment i hope this is enough info. thankyou for your time
Sep 22, 2009 at 6:50 AM
NETSRIK18
  • 5 POSTS
correction i put it is the engine i do not believe it is i feel its in the front end somewhere
Sep 22, 2009 at 6:53 AM
IMPALASS
  • 3,112 POSTS
Hello - Thanks for the info.... My suggestion is take the car to a couple of front end shops and have them check it out and provide an estimate to include the front end alignment. A couple estimates should give you a good idea and you can check what one says with the other. Yes, front ends need grease.......that bad thing is many times the original parts don't come with grease fittings.....the new part does. Weird huh.....Anyway......when you are getting the front end aligned also have them grease it. If parts need to be replaced, again, compare what one says to the other. Possible your belt since it happens when you turn.........it may be your belt tensioner......below is a way to check to see if the tensioner is within spec.........
https://www.2carpros.com/forum/automotive_pictures/248015_tensionor_1.jpg
Still with about 110K the tensioner could be replaced.....they aren't that expensive.......that would ensure the alternator etc are getting the proper power to work.
Sep 22, 2009 at 8:34 PM
NETSRIK18
  • 5 POSTS
got it greased so far so good
Sep 23, 2009 at 6:26 AM
IMPALASS
  • 3,112 POSTS
Hello –
Sounds good….keep me posted
Sep 23, 2009 at 5:30 PM
