1995 Ford Thunderbird oxygen sensors
1995 FORD THUNDERBIRD
150,000 MILES • V8 • 2WD • AUTOMATIC
CG4
my engine run irraticly when accelerating.I have replaced 1 oxygen sensor, and 1 maf sensor.
Aug 22, 2010 at 2:43 AM
Could be caused by one of the following:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Knock sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard it
Aug 22, 2010 at 3:59 AM
