1994 Ford Thunderbird Vibration/
1994 FORD THUNDERBIRD
SVARGASJR
1994 Ford Thunderbird V8 Two Wheel Drive Automatic
While driving my car, there is a rough vibration when the vehicle shifts from third gear to fourth gear and goes away after the shift is completed. Another way it disappears, is if you floor the accelerator.
What could this be?
Apr 17, 2010 at 8:00 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello and thanks for donating
First off, is the check engine light on (trouble codes stored) ? If so, what code(s) are stored?
It could be a driveline issue or a misfire issue. I would suggest checking for a frozen / faulty u-joint. To check it, unbolt the driveshaft and remove it then articulate the joints.
Apr 18, 2010 at 11:41 PM
