1994 Ford Thunderbird timing cover
1994 FORD THUNDERBIRD
CHAPHILL
Engine Mechanical problem
1994 Ford Thunderbird 6 cyl Two Wheel Drive Automatic
I need to replace the timing cover gasket in my '94 tbird. Is there anyway to remove the cover without removing the oil pan?
Jul 8, 2008 at 11:10 PM
AIRSOFTSOLDRECN9
  • 348 POSTS
Unfortunatly, it does not look as if you can remove it without simultaneously removing the oil pan. However, removing the oil pan is one of the last steps so you can try to remove the front cover without dropping the pan. It looks as if part of the front cover fits inside the oil pan, eliminating the possibility of a leaky front oil pan seal, but nonetheless causing a real headache. Ford has always gone above and beyond to make relatively simple tasks major repairs.
Jul 8, 2008 at 11:56 PM
