1994 Ford Thunderbird RAW FUEL LEAKING OUT DRAIN HOLES IN M
1994 FORD THUNDERBIRD
87,000 MILES • V8 • 2WD • AUTOMATIC
DJGRETKA
I saw a similar problem posted and no answer to the problem. The car is bellowing white smoke, I thought it was a head gasket but upon further investigation I noticed puddles of raw fuel under the drain holes of both mufflers. I replaced the fuel regulator and it made no difference. I replaced all of the injectors and the problem is the same. It is like something is telling the computer to overfuel. Any ideas what could cause this ?
May 16, 2010 at 6:53 PM
Could be the injectors leaking or the coolant temperaure sensor is stuck in the open loop mode.
May 17, 2010 at 12:26 AM
