Every 10-15 strat-ups I cannot stort engine. It takes several turns the key to be able to start. Recently replaced: battery, starter, module, distributor stator and ignition switch (twice). Every time I changed ignition switch there is improvement for a couple of weeks, after that it is the same problem. The car is in very good condition, clean inside and out. No corrosion and engine is clean inside as well. Checked cables to starter connections and not seen any problem.
Any suggestion what else to look into?
Apr 8, 2010 at 7:23 PM
