1991 Ford Thunderbird Oil change light
1991 FORD THUNDERBIRD
303,526 MILES • 6 CYL • 2WD • AUTOMATIC
Could you tell me how to reset the Change oil now light on my dash above the radio? IT has analog gauges and the factory radio.
Jul 22, 2008 at 1:16 PM
2CARPRO JACK
  • 11,533 POSTS
Turn ignition switch to "on" within 16 seconds of turning on,insert small diameter shank into reset switch hole and firmly push in switch. Reset switch hole is located on the eft side of theVMM panel.Keep switch depressed until left side display stops flashing.If not held down this long VMM will not be reset
Jul 22, 2008 at 2:45 PM
