Just off idle there is a hesitation/stumble for my fuel injected 302 V8 1988 Thunderbird. Happens at speed when the accelerated is pressed a little "to maintain speed". You can feel the engine chug as you coast to a red light also. Occurs in ODrive, drive or neutral. Replaced the IAC, cleaned the throttle body, changed cap/rotor, and advanced the timing. Still have it. Other than plugs and wires engine is stock. Anything stronger than slight accelration she runs strong and smooth. Thanks for any help. Phil
Nov 18, 2009 at 12:43 PM
