1984 Ford Thunderbird fuel vent tube seal
1984 FORD THUNDERBIRD
114,500 MILES • V8 • 2WD • AUTOMATIC
TOGETREPAIRS
  • 7 POSTS
The vent tube seal on top of the fuel tank is rotted. I can't locate this part anywhere. How can I use the rotted one and seal it in a way so the fumes and gas seepage doesn't escape the fuel tank? or do you know anyone I can buy this part from?
also, there is a grommet or something at the base of the fuel fill tube where it is attached to the fuel tank and I aslo need to find this part, or a way to seal this so there is no fuel fumes nor spillage from the fuel tank?
Mar 28, 2010 at 5:35 PM
CARADIODOC
  • 34,306 POSTS
Ma ran over a chunk of metal on the highway and put 2" by 3" hole in the side of a metal gas tank. After nursing it halfway home, one mile at a time, (it would have overheated from tearing off the heater hoses to the rear heater), I built up a patch with Mopar RTV sealer, (the gray stuff that gets a little harder and seals through any residue). Never smelled the fumes from then on.
While making hose repairs, I wanted to protect the "temporary patch" from rocks, so I covered it with a thin piece of tin. To protect that from rust and corrosion, I added another layer of RTV sealer. That temporary patch has been on there for over 15 years and has never leaked. It's still my daily driver. The tank has been over-filled many times.
I'm sure Ford and GM have the same RTV sealer with their own name on the tube. I just used the Mopar stuff because I was familiar with it. If it can hold up to that, I bet it would work to seal your tubes. Just be sure to remove any dirt and loose material. To remove it later, you'll have to cut it with a knife.
By the way, it works real good too for sealing arcing high voltage transformers in picture tube-type tvs!
caradiodoc
Mar 28, 2010 at 6:28 PM
TOGETREPAIRS
  • 7 POSTS
I have ben shopping and I need more help. I even called Mopar. I need to knoe specifically the type of Sealent that resists gasoline. I called Ford, autozone, cchecker, NAPA, and no one knows for sure which sealent the RTV Sealer. SOme srae for oil, antifreeze, heat, atc. SO I need the name and possibly the part number if you have the sealent still. I can't even ffind Mopar here in the Phoenix, AZ area.
Any ideas you can use to help me find the right sealer? I am planning on usines it also at the base of the fuel tube where the tube connects to the gas tank if it will work.
Thanks.
Mar 29, 2010 at 12:25 PM
CARADIODOC
  • 34,306 POSTS
See your friendly Chrysler dealer's parts department for part number 82300234 RTV Sealant. RTV stands for room temperature vulcanizing. It comes in a 3 oz tube on a blister pack card. It is also available in a caulking tube, but once opened, it will cure in the tube in a few weeks, so only buy that if you're going to use it all very soon. For what you're describing, one 3 oz tube sounds like it will be plenty.
There are a lot of other brands with a similar product that you can find at the parts stores. The only reason I used the Chrysler stuff is I had some with me for various emergency repairs, and I was very familiar with it.
The place where this stuff really works great is for resealing transmission pans. The Chrysler 4spds will drip fluid that runs across the lower pan flange for days. The more rubbery black RTV sealer will not bond if there is any of that oil residue on the surfaces, so parts must be perfectly clean and dry. The residue should still be cleaned off when using the gray sealer, but if you miss some, it will still bond and seal.
caradiodoc
Mar 29, 2010 at 1:13 PM
