1964 Ford Thunderbird shifter
1964 FORD THUNDERBIRD
89,000 MILES • V8 • 2WD • AUTOMATIC
GPALUCH
When I put the car in reverse and start backing up the shifter falls into neutral.also it will come out of park into reverse by it self.Help
Jan 19, 2010 at 5:50 PM
HMAC300
  • 48,601 POSTS
try adjusting the shifter rod to cure the park reverse problem. It should be adjusted to go into park more. If tis has a fordomatic trans there is a possibility that he centr case support cracked as this was a common prpoblem with them. If it is it can be fixed while in your car......
Feb 13, 2010 at 6:49 PM
