'84 ford tempo oil problem
1984 FORD TEMPO
EMJAY
1984 ford tempo. mileage is unkown as it displays only 45,000 km's but not the hundred thousand mark.
I had oil on the tappet cover. I changed the pcv , still oil, changed valve cover gasket, still oil, changed oil cap, till oil coming out of oil cap. Checked and blew through line from pcv , checked and blew thru line from oil cap to air. I then opened air filter and found oil everywhere in air intake?
could there be another hose that is blocked? I am not a mechanic, so please explain in easy terms.
Aug 26, 2006 at 8:58 AM
TAURUSWHEEL
  • 718 POSTS
Geez, I haven't looked at an older car in a while, is that a throttle body with seperate airbox??? Usually, oil in the air box is a sign of a constricted pcv system,,, I had an 87 Taurus, it had a hose from the airbox to a filter cap on top of the valve cover, that cap had a mesh filter in it... I don't believe there's a mutitude of lines on the earlier cars,, is there a good vacuum pull on the pcv valve??? A good noticeable suction???
Aug 26, 2006 at 11:29 AM
EMJAY
[quote="TaurusWheel"]Geez, I haven't looked at an older car in a while, is that a throttle body with seperate airbox??? Usually, oil in the air box is a sign of a constricted pcv system,,, I had an 87 Taurus, it had a hose from the airbox to a filter cap on top of the valve cover, that cap had a mesh filter in it... I don't believe there's a mutitude of lines on the earlier cars,, is there a good vacuum pull on the pcv valve??? A good noticeable suction???[/quote]
I found out I had a "Blow By" which they tell me that a piston or two have rings broken and have to be replaced......darn........thank you for your reply, it took me a while because I don't have the internet at home......thanks anyway.....
Sep 8, 2006 at 8:29 PM
