1984 ford tempo. mileage is unkown as it displays only 45,000 km's but not the hundred thousand mark.
I had oil on the tappet cover. I changed the pcv , still oil, changed valve cover gasket, still oil, changed oil cap, till oil coming out of oil cap. Checked and blew through line from pcv , checked and blew thru line from oil cap to air. I then opened air filter and found oil everywhere in air intake?
could there be another hose that is blocked? I am not a mechanic, so please explain in easy terms.
Aug 26, 2006 at 8:58 AM
