1994 Ford Tempo weird jolt
1994 FORD TEMPO
160,000 MILES • 4 CYL • 2WD • AUTOMATIC
BR61354
I have a 1994 Ford Tempo. When I drive straight for a bit and I lay off the gas to slow down some, then reapply the gas to speed back up, the car will jolt and make a loud clank noise. It seems that when I step on the gas again, the transmission downshifts and when that happens is when I feel the jolt. I had to motor and transmission mounts replaced and it still does it. Any ideas? Thank you.
Jan 22, 2009 at 1:56 PM
FIXITMR
  • 9,990 POSTS
there are 3 mounts in that car 2 on the transmission(front & rear)1 on the motor by engine belts.it's generally the trans mounts that clunk/clank.also have your other drive components checked.axles,ball joints,stuts,and especially the lower control arm sway bar BUSHINGS!they definately are known for loud clanks with sudden forward/reverse motion.good luck
Jan 31, 2009 at 2:06 PM
