1994 Ford Tempo Very little warm air blowing
1994 FORD TEMPO
123,544 MILES • 4 CYL • FWD • AUTOMATIC
VE3TMT
Very little warm air is blowing in car. The temp gauge used to sit int he middle of "normal" but now barely gets a quarter of the way up. It will go up somewhat, but drops again when you drive. Added more Prestone to the coolant jug, it was just about empty. Replaced the rad cap today.
When I take the rad cap off, there is very little pressure spray. In fact the first time I removed it yesterday, after the car had run for some time, there was no pressure buildup under the cap at all.
I'm thinking air block, but not sure what to try next.
Max
Jan 10, 2010 at 3:32 PM
DANDENISE
  • 8 POSTS
i dont think it wood have an air lock or it wood be overheating. my friend had a similar problem with his taurus it was the controls to open the heater inside the car. i eill check with him and let u no exacatly what it was if u still need help
dan
Jan 15, 2010 at 11:21 AM
VE3TMT
Problem solved. Thermostat was disintegrated.
Had it change when the oil change was done, all back to normal.
Jan 15, 2010 at 1:07 PM
