1994 Ford Tempo Engine overheating in 85+ degree temperatur
1994 FORD TEMPO
LUREEPATRICK
  • 4 POSTS
Engine Cooling problem
1994 Ford Tempo 4 cyl Wheel Drive Type unknown Automatic 126000 miles
My car always overheats when the temperature outside is 85+ degrees. We have tried replacing the thermostat, but that doesn't seem to be the problem. The car has no problems in cool/cold weather, but once it gets warm outside, it immediately overheats & I have to wait for it to cool off before I can start it again. Any advice?
Thanks,
Gina K.
Mar 13, 2008 at 5:48 PM
MASTERTECHTIM
  • 4,750 POSTS
does the radiator cooling fan come on?
Mar 13, 2008 at 5:55 PM
LUREEPATRICK
  • 4 POSTS
This is my husband's auto - I actually just talked to him & he said that the car isn't overheating, but that it just won't run when it's warm/hot outside. It runs just fine in cool/cold weather. He said the gauges read fine - not showing that the engine is overheating.
Mar 13, 2008 at 6:00 PM
MASTERTECHTIM
  • 4,750 POSTS
well you need to find out why it wont run. check to see if it has spark when its dead. remove plug wire and leave it a quarter inch away from a metal surface and crank engine and look for sparks comin out of it. if there is no spark then you most likely need a new ignition module,coil and or coil wire, or the pick up coil. if you have spark the y spray starter fluid into intake and see if it runs. then get back to us.
Mar 13, 2008 at 6:04 PM
LUREEPATRICK
  • 4 POSTS
Yes, the cooling fan does come on. It's definately not the thermostat.
