1993 Ford Tempo water pump
1993 FORD TEMPO
CHASKATOWN
Engine Cooling problem
1993 Ford Tempo 4 cyl Front Wheel Drive Automatic
is it easier to take the waterpump out from the top or the bottom, and also, if it's from the top do you have to take the intake off to get access?
Dec 12, 2008 at 9:55 PM
Hi:
I believe it would be easier to remove it through the bottom. You may find it easier to access the parts through the fender well. Safely support the car, remove the tire and see if you can get to it that way.
Jan 5, 2009 at 1:46 PM
