I am working on a 1993 tempo. customer tried to replace starter relay and got the wires mixed up. I rewired the relay and now when u start the car it runs and so does the starter the only way to disengage the starter is by pulling either the starter or alternator wire off of the relay. Checked the ignition relay and starter all test fine. Could the problem be in the voltage regulator or the alternator itself. also on the power side of the relay there are just two wires the main from the battery and the main into the vehicle everything esle goes on the isolated side. Right?
Oct 27, 2009 at 8:22 PM
