1993 Ford Tempo Engine Cooling problem
1993 FORD TEMPO
TENNAYIA
1993 Ford Tempo 4 cyl
My 93 Ford Tempo overheated so I had a friend look at it and replaced the heater hose. It still overheated so they said it was the head gasket. Which he then replaced also. The problem continued so I then replaced the anti-freeze, had the spark plugs and thermostat fixed, which solved the heater problem but the car is still running hot. I had a second opinion and they then said that some rings needed to be replaced in the engine because of the oil line now. Which the engine would have to be taken out and put on a machine and it would cost at least $800? Can you please assist me with this problem and are they correct?
Dec 9, 2009 at 12:09 PM
FIXITMR
  • 9,990 POSTS
the diagnosis sounds like BS to me!? the only rings i can imagine are the piston rings? why that has anything to do with overheat is beyond me! i think you need a more detailed explanation!
so you are saying that this problem happened suddenly after many miles of trouble free service from the car? anybody check the waterpump and it's belt and idler pulley? is the radiator fine? maybe the head is cracked?
Dec 10, 2009 at 12:42 AM
TENNAYIA
yes I have not had any problems until now. I HAD THE HEAD GASKET AND THERMOSTAT replaced. It still overheats. I think the radiator is fine. There are no leaks but I don't know if they checked the water pump. Please help!!!
Dec 11, 2009 at 6:20 PM
DANNYR2009
  • 30 POSTS
i am no expert but heard that if you see white smoke, that mean the engine is burning antifreeze? If i wouldn't see any white smoke while the engine is running, i would make sure that the radiator is not blocked or some...maybe check the radiator hose going out from the engine is hot, making sure the hot liquid is circulating ?
Dec 14, 2009 at 4:24 PM
FIXITMR
  • 9,990 POSTS
[quote="Tennayia"]yes I have not had any problems until now. I HAD THE HEAD GASKET AND THERMOSTAT replaced. It still overheats. I think the radiator is fine. There are no leaks but I don't know if they checked the water pump.[quote]
you need someone else to check things out for you? this place is for advice, not actual 'help'. rather than spend big money i would get another cheap car that runs good.
Dec 14, 2009 at 8:08 PM
