1993 Ford Tempo blowermoter
1993 FORD TEMPO
BEATE
Air Conditioning problem
1993 Ford Tempo
where in the heck is the darn thing , I turn the knob to have the air but nothing comes out of the vents and I know that I have enough coolant in the air con so I am stuck.
Sep 30, 2009 at 8:13 AM
FIXITMR
  • 9,990 POSTS
it's under the glove box. might be covered by kickpanel plastic. must have air control panel buttons set to something besides 'off' for it to work. could be bad fuse, bad wiring plug, bad pushbutton panel wire connector (melted/burnt) , bad speed setting resistor assembly, or bad/stuck blower motor brushes. when you locate blower, hit/kick it to see if it comes on. that would indicate stuck/worn brushes.
Oct 1, 2009 at 1:43 PM
