1992 Ford Tempo Passenger tire is wabbly
1992 FORD TEMPO
100,000 MILES • 4 CYL • FWD • AUTOMATIC
SHAWNABENGE
we have chamged the lower arm control,upper and lower tire rod ends and the tire still wobbly and sticks out further than the drivers side cocked to the right a little further out, and it wobbles when you drive it, it seems to be almost dragging the right tire in a turn, we checked the steering box and just don't know what else could we can do.... what is wrong with the passenger tire?
Mar 14, 2010 at 9:48 AM
MERLIN2021
  • 17,250 POSTS
Check the hub bearing, it's worn out, should also be making some growling noise as you drive?
Mar 14, 2010 at 9:54 AM
FIXITMR
  • 9,990 POSTS
yes, jack wobbly tire off ground and grab top of tire and pull. it should NOT move. if it feels loose wobbly then the axle/hub wheel bearing is shot!
Mar 15, 2010 at 5:11 PM
MERLIN2021
  • 17,250 POSTS
Thanks for the help...
Mar 18, 2010 at 4:35 PM
