1992 Ford Tempo Car keeps overheating
1992 FORD TEMPO
ELISABETHO
Engine Cooling problem
1992 Ford Tempo 4 cyl Automatic unk miles
Hi I have a 92 Ford Tempo. For a while, the car would over heat if the a/c wasn't on because the fan would only work with the a/c on. 4 days ago it over heated and my radiator cracked. I replaced the radiator. The car continued to get hot and the fan died all together. I replaced the fan. The car still gets hot and over heats within a few blocks - It gets really hot really fast. One of my friends thinks it is the water pump. Another friend thimks there is air in the system and said i should let the car get hot and when fluid stops coming out i should fill it back up and then it should be fine. I have never heard of this procedure - Have you? What do you think is causing the car to get so hot so fast?
Jul 23, 2010 at 11:22 PM
Replace the thermostat don't work check and test the water pump-
Jul 24, 2010 at 12:24 AM
ELISABETHO
I had a mechanic look at it today and he thinks its a cracked head gasget since i am losing compression
Jul 24, 2010 at 2:38 PM
Thinking is a lot different when you perform a block and pressure tests to confrim if its actually the headgasket-could be a cracked head or block or the intake manifold is leaking-Guessing is a bad idea could be costly.
Jul 24, 2010 at 3:55 PM
FIXITMR
  • 9,990 POSTS
if the repairs are gonna cost as much as another used car, get another car! these can be a real EXPENSIVE PAIN!
Jul 26, 2010 at 1:11 AM
ELISABETHO
It did end up being a cracked head - Thanks you guys!
Jul 31, 2010 at 1:09 AM
You're welcome and TY for using us as you auto repair site
Aug 2, 2010 at 12:27 AM
