1991 Ford Tempo possible fuel pump problem
1991 FORD TEMPO
22 MILES • 4 CYL • FWD • AUTOMATIC
CMSUSTUD
My tempo roughly starts by pressing the gas peddle down and in order to drive it you must keep pressing the gas. I have changed the fuel filter. Someone I knew stated it could be the fuel pump. Could this be correct?
If so, how much is it to fix it usually?
Apr 16, 2008 at 11:02 PM
BMRFIXIT
  • 19,053 POSTS
I would suspect a vacuum leak or stuck idle control valve
clean throttle plate and or replace idle valve
make sure no vacuum leak and PCV valve ok
Apr 17, 2008 at 5:53 AM
