1991 Ford Tempo no heat
1991 FORD TEMPO
91 FORD TEMPO
Heater problem
1991 Ford Tempo Two Wheel Drive Automatic
I have a 91 ford tempo and I have no heat you can get in and turn it on and it does nothing you cant hear a fan or anything you cant even feel any heat whatsoever. I have checked the fuses but that is all I dont know what else to do. Could you please tell me what I can do to get my heater to start working it is winter time and I have no defroster or anything?
Nov 9, 2010 at 9:55 AM
Check and test the blower switch, blower motor relay, blower motor resistor and blower motor
Nov 9, 2010 at 1:11 PM
FIXITMR
  • 9,990 POSTS
is this the first cold weather for you and this car? do a search of this tempo forum key word heater/blower for lots of info. these cars are notorious for burning out wiring plugs/switches for the heater fan! ford should have put a power relay right at the blower instead of wiring high amps all thru the system! but it also could be your blower is dead. its under the glove box area. test for voltage at blower. usually the motor brushes wear out. the air controls are vacuum operated and it all feeds behind the central dash button box! see if you hear the blend doors operate when push buttons! the vacuum is fed by a small plastic line from the firewall which is right behind engine! if your blower motor is good you can cheat by running 12 volts directly to it using a household wall switch!
Nov 9, 2010 at 6:10 PM
