1990 Ford Tempo Power Locks
1990 FORD TEMPO
MRSLADY627
Electrical problem
1990 Ford Tempo 4 cyl Two Wheel Drive Automatic
The power locks dont work and the two back doors are locked with the child locks on. We're unable to pull the locks up to unlock them and unable to open the doors to get the child locks off. The fuse has been tested and is good. How do you suggest getting the doors unlocked and open?
Apr 7, 2008 at 5:03 PM
WHY4
[quote:93cf817acc="mrslady627"]Electrical problem
The power locks dont work and the two back doors are locked with the child locks on. We're unable to pull the locks up to unlock them and unable to open the doors to get the child locks off. The fuse has been tested and is good. How do you suggest getting the doors unlocked and open?[/quote:93cf817acc]
You need new door lock actuator or remove and use key to lock/unlock Front doors only .
Back doors last one I did I had to cut holes in inside door panels then cut the actuator rod going to door latch/look .Heads up this may help you out Goto bone yard find read door with panel off and look for actuator and look over inside door .
Apr 20, 2008 at 4:54 PM
