i bout this car cheap! however the tires are pigeon toed and i need to know how to fix this problem as the tires howl if you go over 30 miles per hr so it cannot be driven at this point. i tried losening the strut assembly to push the upper tire in but it won't budge. the person i bought the car from had a "friend" replace the drivers side rack and pinion ball joint and when he got the car back the alignment was screwed up, and it was not like that prior to the repair. he tells me that you could let go of the steering wheel and it would drive in a straight line,now if you let go it hooks a drastic left turn
Jan 23, 2010 at 10:40 AM
