I just got a 1989 ford tempo. It's auotomatic and runs good, but the front right tire has something wrong. When i drive it makes the whole car vibrate up and down. I don't know why. I checked it to see if it was flat but it's not. Also the stearing wheel has to be turned about 20 degrees to the left in order to go streight. Why? also The battery keeps going dead(well, almost.) It dosen't seam to be charging. When i go to start it, it sounds very weak and just barley gets the car started. I read another area where you said to check for battery leakage, and am happy to say that the light did not glow (no leakage), is it the alternater? Also the cruse control dosn't work. Any ideas. Another thing, my aunt, who gave me the car, said there was a cracked hose. i saw a puddle under the car, but didn't see a leak. What could be leaking. Brake fluids fine, I pressed the brakes severl times with no leak, and the car dosn't heat up(antifreaze is fine) so what else could be leaking? One last thing. Where is the fuse box at? I can't find it and would like to replace all the fuses with new ones. I found the paper on the glove compartment but it dosn't say where to find the fuses. I know it's a lot but please try to answer all my questions. thanks. :(
Feb 13, 2006 at 11:10 AM
