1988 Ford Tempo starting
1988 FORD TEMPO
170,000 MILES • 4 CYL • 2WD • AUTOMATIC
MIKEKERR
the car started and ran for just a few seconds and died, wouldn't restart. checked fuel pump, fuel filter, and air flow to intake. all checked out ok. almost think it might be flooded, weather has changed and harder to start.
Oct 26, 2010 at 10:09 PM
FIXITMR
  • 9,990 POSTS
what kind of fuel injection do you have? TB or multiport?on TB you can take off the bonnet and watch fuel spray. you can also disconnect injector plug to elimnate flooding. have you checked spark at plugs? these cars are notorious for bad/iffy coil wires. you should also pull your plugs and sand blast/clean or replace if they are dark. what makes plugs short out is when the porcelain below the firing tip is coated with black carbon residue. wet fuel then provides conductor for short. i've cured a lot of no stat almost starts on tempos with new plugs!
Oct 27, 2010 at 3:05 PM
