only starts when you turn the key, will only stay running if you hold the ignition key
Jun 26, 2010 at 8:36 AM
FIXITMR
CERTIFIED EXPERT
could be the ignition switch(not the key cylinder) that is down on lower part of steering column. connects between with a steel rod. i've actually taken apart the ignition switch unit and repaired it. you can do a search of this tempo forum for "ignition" to get lots more answers/ help!
