Engine Performance problem
1985 Ford Tempo 4 cyl Two Wheel Drive 132000 miles
1985 tempo been sitting a long time will start with small shot of starter fluid. After it will only run while you pump the gas, this can go on for as long as you pump the gas, but try and hold it at any rpm and it dies from lack of fuel. It has the throttle body single point injection and the throttle body has been rebuilt the injector checks out OK, the fuel filters have been replaced, the fuel lines were blown out and the fuel drained and replaced with fresh. All electrical connections have been cleaned to the best of my abiities. So, what do you think, is their a computer in this thing? I'm just not sure where to go from here.
Thanks for any input. Peter
Jul 22, 2009 at 1:51 AM
