Taurus dome light staying on.
FORD TAURUS
KIMGRAMPS
  • 4 POSTS
1999 Taurus SE wagon, 3L, 140,000Km
The dome light on my taurus is staying on all the time. I suspect a faulty door switch, is there a way to find out which door is causing the problem and is it an easy job to change the switch?
Any help would be appreciated.
Aug 14, 2007 at 7:55 PM
SERVICE WRITER
  • 9,123 POSTS
You need to get some lubricant like WD-40 or similiar. Spray the door lock latches and open and close the doors. The fronts are usually the offenders. Spray and work them a handful of times and it will very likey solve your problem. Seen this a million times....Okay i exaggerated... slightly less than a million times. :wink:
Aug 14, 2007 at 8:01 PM
DMBMARTIN12
I have one, too. Exactly like they said. wd-40 does wonders. i spray my doors with every oil change and keep a can in the trunk just in case. it was very annoying for a while before i figured it out though. happy trails
Aug 31, 2007 at 1:13 AM
