smog test failure diagnostic code PO340
1934 FORD TAURUS
FLASHHEAT
  • 8 POSTS
I have a 1997 Ford Taurus 3.0L SOHC. During my last smog test I failed with a PO340 trouble code. I was curious if it could mean anything else than a bad camshaft position sensor?
Feb 26, 2007 at 10:33 PM
SERVICE WRITER
  • 9,123 POSTS
It sure could and probably does. Under the cam sensor is a syncronizer that is also probably bad. A window gets bent on the syncronizer that wipes out the sensor as well. You'll need a special tool to change that.
Feb 27, 2007 at 5:33 AM
