power door lock problem
FORD TAURUS
J12251225
  • 6 POSTS
1994 Ford Taurus, 3.0L, 4 doors, 187000 miles, without remote control for door locks. None of the four power door locks will unlock when I try to unlock them from either the driver- or passenger-side switches on the armrests. No sound is made that would indicate any activation is happening when I depress the unlock side of either switch. Both these switches still function, however, to lock all four doors. Is there a relay that needs to be replaced?
May 6, 2007 at 5:01 PM
J12251225
  • 6 POSTS
justanold,
Thanks for the helpful response. The implications seem to be that because the passenger-side door lock switch is not currently unlocking the doors either, that the signal from that door lock switch must pass through the driver-side door lock switch on the way to the 4 door lock motors. Is that correct?
Regards,
Jim
May 6, 2007 at 6:57 PM
J12251225
  • 6 POSTS
Dear justanold,
Your advice was right on target! I removed the driver-side power door lock switch. I happened to show it to a friend at work, who recommended I take it apart. I did that and then cleaned all the internal and external contacts. I put everything back together again and then depressed the unlock side of the driver-side switch. I was certainly pleased when I heard the "thunk" of the doors unlocking. As you predicted, the switch on the passenger side now unlocks as well.
Thanks for the great advice!
Regards,
Jim
Alexandria, VA
May 12, 2007 at 9:05 PM
