P CODES 1744 1743
FORD TAURUS
SWIPERTHEFOX22
  • 9 POSTS
HELLO MY NAME IS NATHAN AND I HAVE A 97 FORD TAURUS 3.0L OHV TROUBLE CODES 1743 AND 1744 Came up and i dont know why because i have already relpaced the torque converter clutch silinoid and the pressure vavle, but it still is stuck in the off position. how can i go about fixing that or getting it out of the off position or do i have to replace the fluif pump also?
Mar 9, 2007 at 11:47 PM
TAURUSWHEEL
  • 718 POSTS
I'd say take it to a locally-owned trusted trans shop and have them, if they're equipped, test the tcc circuitry, you didn't damage any of the connectors or associated pieces while replacing parts???Here's a list of the procedure:
² C2: CHECK ELECTRICAL SIGNAL OPERATION
² C3: CHECK CONTINUITY OF SOLENOID SIGNAL AND VPWR HARNESS CIRCUITS
² C4: CHECK SOLENOID/HARNESS FOR SHORTS TO POWER AND GROUND
² C5: TRANSAXLE FUNCTIONAL TEST
² C6: TRANSAXLE DRIVE CYCLE TEST
² C7: CHECK RESISTANCE OF SOLENOID/HARNESS
² C8: CHECK SOLENOID/HARNESS FOR SHORT TO GROUND
² C9: AX4N INTERNAL ELECTRONIC DIAGNOSTICS
² C10: CHECK INTERNAL AX4N HARNESS (CONTINUITY)
² C11: CHECK INTERNAL AX4N HARNESS (SHORTS TO GROUND)
² C12: CHECK SOLENOID RESISTANCE
² C13: CHECK SOLENOID FOR SHORT TO GROUND
Mar 11, 2007 at 4:12 PM
