Low Coolant Light On
FORD TAURUS
DEEBEE
  • 4 POSTS
2000 Ford Taurus 70K Miles. My low coolant light had been coming on occasionally over the past six weeks or so. Happening more frequently now. Coolant reservoir is full , with no apparent leaks. Any ideas what the problem could be? Thanks in advance.
Jan 2, 2007 at 7:07 AM
SERVICE WRITER
  • 9,123 POSTS
Somtimes the sensor will go bad in the reservior. Rap on the sensor lightly and see if anything changes. You have flushed the coolant by now right?
Jan 2, 2007 at 7:08 AM
DEEBEE
  • 4 POSTS
No, coolant is still original as far as I know. Where is the sensor located? Thanks again!
Jan 2, 2007 at 7:16 AM
SERVICE WRITER
  • 9,123 POSTS
Get the coolant flushed. The properties of the coolant get diminished and create a situation where you'll have to spend more time here. :)
The coolant level sensor may be part of the cap on the reservior or at the bootmo of the reservior. You see and electrical harness going to it either way. It may not change when you tap on it or it may. I don't recall any other problems that I encountered for triggering that light, unless the reservior was really low.
Jan 2, 2007 at 7:37 AM
