loss of oil pressure as engine warms
FORD TAURUS
SHAFTDADDY
My 1999 Ford Taurus, 3.0 liter engine, 118,500 miles was put in the shop for a cooling problem, the next day I drive to work only to break down again this time with a blown head gasket. The mechanic replaces the heads and head gasket. I drive back to work the next morning, and start having oil pressure problems about 80 miles into an 85 mile trip. I take it to a seperate mechanic who takes down the oil pan, cleans it out and replaces the sending unit. He said the first mechanic left all kinds of sludge and gasketing material down in the engine which clogged the sending unit and pickup tube up. He also said the main bearings are now weak and a direct result of this. I am still getting low oil pressure in the engine especially after it gets warm. Before it warms up I have pressure at 1000 rpm but after it warms my oil pressure light comes on at 1700 rpm. Can the oil pump itself cause my problem? Is there any way to fix this without rebuilding the engine? I travel approx. 170 miles round trip a day & this was my only reliable vehicle before the trouble and only way to work.
Feb 28, 2007 at 9:00 PM
TAURUSWHEEL
  • 718 POSTS
Did the engine overheat the first time??? You mentioned a cooling problem, overheat??? It's probably one of the worst things that can happen to an engine nowadays, most likely the headgasket issue is related to the first problem.. as for oil pressure, weak bearings, does that mean excessive clearance????, which could contribute to lower oil pressure.. oil pump itself doesn't matter hot or cold,, hot oil less pressure then cold of course and that could show, when hot, if the bearings are bad, if internal engine parts are bad, then rebuild is the only way, no magic
Feb 28, 2007 at 10:49 PM
SHAFTDADDY
Yes the original problem was overheating. I asked him to solve the problem. I never let it get very hot though. If I saw it was going to overheat I pulled off the road and let it cool. That is when the trouble began. He said the head gasket blew because #6 cylinder was not firing leaving it cold while everywhere else was hot. Also the impeller on the water pump had rotted away. That was changed also.
Mar 1, 2007 at 10:02 AM
