instrument panel lights out
FORD TAURUS
CE347
2002 Taurus 97000 miles 3.0 flex fuel. Instrument panel lights won't light when headlights are turned on. floor shift ind., radio and heat A/C lights come on and work fine. When headlights are turned on, only l & r turnsignal lights illuminate. all gauges and warning lights work fine. Was told its most likely headlight switch but want to be sure I shell out over $100.
Mar 11, 2007 at 5:27 PM
MERLIN2021
  • 17,250 POSTS
Dumb question, but, is the dial turned up? Also check the instrument cluster fuse. If your ambitiuos
and have a test light, unplug the connector and check for power!
Mar 11, 2007 at 8:39 PM
