i have a 1993 ford taurus The problem is that my headlight turn on and off while driving and after few blinks they go back to nornal[/b]
Sep 26, 2006 at 12:32 AM
NOS
CERTIFIED EXPERT
does it do it with or with high beams?(NOS) 8)
Sep 26, 2006 at 7:23 PM
JULESAZ
MEMBER
night sensor stopped working, then the dash board lights went off, then the rpm's stopped working then the car died, and has to be jumped to get started again, battery was replaced as was the alternator two times, it starts off working correctly, then starts over with the dash lights going off, then the rpms not working then dying. Help? Could the broken "sensor" be causing these problems? Julia
Sep 27, 2006 at 10:40 PM
NOS
CERTIFIED EXPERT
i think the problem is a real bad short, the key words you told me was the battery and the alternator have been replaced twice. there is something shorting these thing out.first do this take the knee panel off under the steering wheel and check to see if there are any burnt wires or switch or any thing of that sort do this first. were going to have to take this one step at a time. for the simple reason if something is taking out both alternator and battery that explains why the car dies and the lights go out, cause there is no voltage to run nothing. if you loose the alternator the battery would run car till the battery run out of voltage but not both.(NOS) 8)
Sep 28, 2006 at 8:36 PM
BUBBA_KOSKI
CERTIFIED EXPERT
there is one way for both to go out but not within a couple mins. if the battery goes first which actually can happen the the alternator will strain and work 2x over time to "charge" the battery causing the alternator to short, but if problem keeps occuring then follow NOS suggestions. 1 STEP AT A TIME but when you changed the alternator make sure you put it on a fully charged battery.
Sep 28, 2006 at 10:26 PM
JULESAZ
MEMBER
Thank you both so much for replying, I will try your suggestions and let you know the out come! Julia :D
