Subject spells out the current issue. Car with 96K miles. I had a P0172/174 code issue that turned out the be a hole in the PVC hose. I replaced it but while doing so removed the Plenium and found excess carbon in the tintake zone. I cleaned all of the with Carb cleaner and replaced all gaskets and worn hoses. At same time battery went on the fritz. After assy I then received P0102 code. I replace battery and still recieve P0102 code. Symptoms are transmission upshifting rough (never did before) and MIL light. Engine Diag show fuel trim constantly at 99% on B1S2 and B2S2, I assume this is lean when positive. Engine runs great aflter PCV hose fix and carbon clean-out.
So what's with S2 fuel trim and tranny shifting?
Sep 15, 2007 at 9:39 AM
