Engine noise when atmospheric moisture goes up or when rains
FORD TAURUS
RAGHUJOSHI
I have a Ford Taurus 2001, 129K V6 engine. I have noticed that there will be a noise(as if some thing is rotating and hitting the engine ). When I got it checked, it was thought that a camshaft timer and base were the problem. After replacement, i did not observe any great change. This noise particularly occurs when there is a lot of moisture in the air or when it rains. It does not occur in extreme cold or extreme heat or normal weather. i feel it has to do something with moisture content. Can I get some insights into this.
Mar 19, 2007 at 10:08 PM
2CARPRO JACK
  • 11,533 POSTS
carefully inspect the drive belt and tensioner.
Mar 22, 2007 at 3:46 PM
