I have been working from a shop manual to remove a cylinder head from my 1999 Taurus (148k miles) with the 3.0 DOHC 24v. I have at least 2 broken exhaust valves that I need to replace. I have followed all the steps (practically gutting the engine compartment) to remove the timing chain cover. The problem is (and the book doesn't address this) that it appears that the AC compressor bracket is attached to the cover (not with bolts, looks like metal dowels). Now, the AC compressor bracket is bolted to the block and also serves as the attachment point for the front motor mount.
I have looked for a work around, but it appears that I will need that cover off to remove the timing chain tensioner (attached to the cylinder head). I'm trying to do this without pulling the motor. Any ideas?
Mar 19, 2007 at 10:46 AM
