Problem started suddenly today. I started it up and shifting from Park to Reverse was a little stiff, but shifting into Drive was very difficult. No problems or sounds while actually driving; the transmission worked fine. When I got home I put it into Park, but it was stiff. Almost to the level of forcing it into the desired gear, but not quite. I checked my transmission fluid and it is within acceptable levels, if a bit low. I'm hoping this is going to be easy to fix; if I have to take it to a mechanic I will need to either borrow money or park it for a while and save up. Thanks in advance for your advice.
Jun 11, 2010 at 5:12 PM
