accelerator sticks - not slowing down?
2005 FORD TAURUS
OUTFIELD98
2005 ford Taurus, 60k miles, 6.0 engine. When I am driving, I will press on the accelerator, sometimes the idle sticks, I have to tap on it a couple of times for it to go back down, I tried to clean out the throttle intake but it seems like it didn't work, could this be a sensor issue or cable problem and how hard would it be to fix myself?
May 26, 2007 at 10:40 AM
RUDPRO
  • 224 POSTS
On the side of the throttle intake there should be a lever with a spring in it and a cable attached to it. Try operating it by hand, this will open the throttle plate. When you let go of it, it should snap back firmly. If not, the spring might be loose or damaged. Try it and post back.
May 26, 2007 at 7:15 PM
OUTFIELD98
The spring worked fine, i used cleaner to clean out throttle intake and throttle itself,, there was a lot of buildup and it was causing idle to stick. My accelerator problem is fixed, thanks for your help!
May 28, 2007 at 6:09 PM
PAUL WILBURN
when i put on gas car engins runs fast but car dosen't respont, need reduce fuel petal move car along slowly started friday.
Aug 21, 2020 at 1:55 PM (Merged)
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:20c64b143d="paul wilburn"]Engine Performance problem
2005 Ford Taurus 6 cyl Two Wheel Drive Automatic 60000 miles
when i put on gas car engins runs fast but car dosen't respont, need reduce fuel petal move car along slowly started friday.[/quote:20c64b143d]
Ok. I believe you are having a transmission problem. You say that when you press on the gas the engine reves but the vehicle doesn't speed up the same as engine speed.
Is your check engine light on? if so and you can get it to your local auto zone or similar have them pull the codes then post them here in forum.
Have you had a transmission service done on the vehicle? If not check fluid, if looks brown it is burnt and you will need to have the tranny fluid and filter changed.
STEVE W.
  • 15,113 POSTS
Disconnect the battery cables and short them together, that will clear all learned data from the ECM.
Then try a test, Disconnect the IAC and see if the idle drops.
If it idles down and the throttle responds when you pull the IAC connector off, verify that you have the correct IAC valve, there are a couple out there that are supposed to be correct but actually are the wrong part. One with a brass insert and spring and one with no insert. You want the one without the insert.
DAVID JIMENEZ2
  • 16 POSTS
Thanks! Will try the battery leads shorting step today after work. That is a really good idea, wish I thought of that! With the IAC valve, what part is brass? The plunger, the cup? Or better yet where on the IAC is the insert located?
STEVE W.
  • 15,113 POSTS
The brass insert is inside the valve opening. The issue is that there are two 3 liter engines, used and the valves will physically interchange. Then there are two different designs of one of the valves as well.
DAVID JIMENEZ2
  • 16 POSTS
After pulling and shorting battery cables there is better idle, less frequent hunting of rpm in Park and gear with brake applied and doesn't go so high as before when turning on the climate control, but the sticky accelerator issue is still there. Just not as pronounced. If I unplug the IAC the idle drops a little bit with no climate control on and in Park, and with it on it almost dies when the AC clutch kicks in every ten seconds or so. But when I drive down the road with it unplugged, the sticky throttle problem goes away entirely. I have checked the IAC and it is not a brass model, and the spare I purchased is a brass model and when I plug the brass one in, the rpm goes nuts, so I am guessing it is the one for the other engine? The original IAC was thrown out last year so the one I have been running on is supposedly the correct one? I noticed the brass one has a stamped Roman numeral I stamped inside the chamber and the one without the brass insert has a Roman numeral II. You mention there are two different valve designs? How can I tell which one is for this car? I am tempted to adust the idle manually and leave the IAC unplugged. Thanks so much for your help. Do you have any further suggestions/guidance?
DAVID JIMENEZ2
  • 16 POSTS
Here is a side by side comparison after cleaning the one without the brass.
STEVE W.
  • 15,113 POSTS
There is the problem; Both of those are the other design with the spring loaded valve.
This is what it should look like. Notice no spring or bushing. Ford # 1F1E-9F715BA
When it is at idle that valve stays really close to closed with the ECM sending a pulsed signal to it to open it sort of like this (Closed = _ open = ^) __^__^__^__^^^__^^^^__ ). The more "open" pulses the more air the valve lets in and the idle goes up.
In your case the spring is holding the valve open and the ECM still pulses the valve once you let off but with the spring there the valve isn't actually closing until the constant pulse from the ECM sort of hammers the valve closed.
I would be very tempted to visit the parts store, buy a new one, open the box to verify it is correct, bring it home. Then take a pair of needle nose pliers and remove the spring on the current valve, put it back on and see if the sticky throttle goes away. I am betting it does. Then return the new part for a refund.
Once you get the valve fixed, reset the idle to correct spec and you should be good.
Then you can be like the rest of the mechanics in the world when you discover that the "right part" is sometimes the wrong part, thanks to a minor revision, or an "improved" part that is not.
RANDAL DEAN
Car eventually slows down, but only after quite a while. I can travel miles at forty five mph without touching the gas. This is true if I use the cruise control or not. If I apply the brakes, it will slow down, but it is like the gas pedal is still being pressed down. When I place the transmission in neutral, the rpm's go up. This only happens when in gear. When I come to a stop, I have to brake until it shifts to first gear, then it settles down to a manageable rpm. It idles at 750 rpm's at a stop. But once I take my foot off the brake, rpm's will slowly climb up to 1,500 rpm's shifting into the next gears. I also noticed that while accelerating up to fifty five to sixty mph, there is sometimes a "rough" spot around forty five to fifty mph where the car sometimes loses power or shudders very briefly and feels like I ran out of gas or is trying to shift gears, but then just as quickly, it recovers. I also must add that whenever the climate control switch is placed in any position clockwise of the center off position (floor and dash, floor, WinDefr and floor, WinDefr, respectively), or in the two AC settings, the rpm's spike up to 1,500 rpm's and the AC clutch engages. This does not happen when using the dash vent position. I thought that the clutch should only engage when set to AC/MAX AC or the two defrost positions, but maybe that is how Ford does it. In any case, the spike in rpm cause the vehicle to suddenly lurch if in any forward or reverse gears. There are no codes being thrown by the computer.
STEVE W.
  • 15,113 POSTS
Oh, forgot the heater core issue. A way to fix that is to clamp off the heater lines, remove them, flush the core both ways, then install a coolant filter in the line that sends coolant to the heater. There are a few out there. I like the cheap way myself. Get a set of solid brass garden hose ends (male and female) in 1/2" or 5/8" (to match the heater hose size) and a few of the filter screens like you put in a pressure washer hose. Add those to the line with a couple good clamps. They will catch the larger crud that likes to block the core. For folks who want the ready made version google
RF002 - Universal Heater Core Coolant Filter Set
Or you can get the "fancy" version from these folks.
http://www.ganofilters.com/
One other option I did on another vehicle is to install the fittings in both lines. (one set reversed from the other) This allows the option of bypassing the core if it starts leaking and you can easily flush the core or cooling system in both directions with a garden hose.
Good afternoon,
This could be either the idle air control motor or the throttle body.
I would clean the throttle body first before going to the idle air control.
DAVID JIMENEZ2
  • 16 POSTS
Steve, where the heck were you last year when I started this mess?! You have been incredibly helpful in my quest to fix this car. I have literally put over eighty man hours the last two weeks chasing this problem, not counting the time from last year, countless visits to the "parts" store, and mom and pop mechanic shops. I have the part on the way this time I am cutting my losses and ordering directly from the local Ford dealership. (actually i am adding to my $$ losses, but saving myself further heartache and time visiting all the parts stores in search of this elusive part).
As far as the heater core flush/filter install goes, I will have to look into that. I would have to take it to a friend's garage (with heat and running water and a drain) to do that, I think I would do your method of just buying the parts instead of the "kit". This car seems to get that core plugged issue, something must be rotting away internally to plug it up so badly, so quickly after a flush (second time in two years). One possibility for the low heat issue could be a fresh air mixer/vent damper not closing/opening fully when in the max heat position (so i'm told by the guy who flushed the core last time). Do you know how to troubleshoot this so I can eliminate it from the possibility. I just had the thermostat replaced on last Friday (no effect), and the core flushed on Monday worked better-ish for a day, and then low heat issue came back a day later.
Thanks again, and I will post the results on the IAC later today.
STEVE W.
  • 15,113 POSTS
When you do the flush, do it in the reverse of the way the water flows through it. I made a core flushing machine because I got really fed up with heater cores.
For the blend door, you remove the lower trim panel (behind the dash, passenger side foot well) Blend door and actuator is right there. To get the upper bolts easier you can pop the glove box out.
Sort of like this....
https://www.youtube.com/watch?v=xK7rP49gfio
Note the time when he says to watch this part as it will fall down. That lever connects to the blend door. If you watch that while moving the temp button it will tell you if the door is closing.
DAVID JIMENEZ2
  • 16 POSTS
The new OEM IAC works great! Just need back off the throttle stop screw a little bit (it's nearly flush now}, as the deceleration is still a little too sluggish for my likes.
Aug 21, 2020 at 1:56 PM (Merged)
STEVE W.
  • 15,113 POSTS
Do another battery cable ECM reset with the new valve. It will need to re-learn the idle characteristics of the new valve.
DAVID JIMENEZ2
  • 16 POSTS
I did that when I installed the new IAC. I now do that every time I change a component. I read somewhere that the throttle stop screw should be set fully backed off and then given one full turn clockwise, mine is set at 2 or 3 full turns.
DAVID JIMENEZ2
  • 16 POSTS
Everything is running just fine now. Time to give it back to my daughter. This was quite the learning experience! Thanks again, Steve!
STEVE W.
  • 15,113 POSTS
Remind her that the next repair is her job... (yeah right, like a dad is going to do that)...
Glad you got it all sorted out. You're very welcome. Thank you for using 2CarPros.com Please return with any auto related questions, we're here to help.
DAVID JIMENEZ2
  • 16 POSTS
OK, So maybe I spoke too soon. The idle is fine, but when I take my foot off the gas when in gear going down the road, the car still doesn't slow down immediately like it should. It does start to slow down, but it really takes its time. I have a scan tool hooked up and am looking at the TPS reading and it goes back to 16.1% (closed throttle) when I let off the gas. There is no dead spots and it seems to read smoothly throughout the travel. I checked at parked idle closed throttle and it reads 16.1%. Is this normal? Shouldn't it read closer to 0%, as I have the throttle stop screw backed almost entirely out of the threads. I understand that when I put the TPS on, I have to tilt it into position and back down again so that the lobes mesh properly, so there may be a greater than 0% reading due to that. I just thought the ECM would adjust for that after an ECM reset and display a "corrected" % reading to show a more usable reading to the scan tool, but maybe not.... Any ideas? I can't seem to find any other vacuum leaks that may cause the excessively slow return to closed throttle speeds. Thanks!!
STEVE W.
  • 15,113 POSTS
TPS should read lower than 16% at idle. Sounds like it's a bit out of adjustment.
You won't see 0% because the sensor always passes some voltage even at fully closed throttle but 5% or so is about normal with a vehicle that has an IAC valve.
Here is a question. If you head down the road, let off the throttle and it doesn't slow much, shift into neutral. What do the rpms read and do they rise at all when you shift to neutral?
DAVID JIMENEZ2
  • 16 POSTS
Steve, when I shift to neutral the RPMs pretty much stay the same immediately after throttle release, then begin to gradually drop slowly a few hundred RPMs, then they shoot back up for a couple-3 seconds before beginning the slow downward trend again as the car slows.
DAVID JIMENEZ2
  • 16 POSTS
Ok, so I paid more attention to the "shift-to-neutral-while-in-gear-going-down-the-road-with-foot-off-the-gas-scenario". The RPMs actually do shoot up a 100-150 RPM immediately after shifting to neutral. This only happens when in the higher gears, though. When in first gear it is not evident -it is more responsive when in first gear. So on the way home I picked up a new TPS and tested it against the old one. The new one actually reads 18% throttle at idle vs the 16.1% on the old one. I went ahead and unplugged the IAC to see if it had any effect at idle, and it didn't have any effect until the load increased when the compressor turned on -then the engine started to stumble and run rough. I plugged it back in and then the idle got smooth again. I give up... I have absolutely no idea what to do next!
STEVE W.
  • 15,113 POSTS
OK, forgot to ask this. If you are setting still, trans in park. What does the engine do if you hit the gas and let off? Does it drop right back to idle? Now if you drive it and shift down one gear (out of overdrive) does it slow down better?
There was an issue on 97-2000 Taurus models where they didn't engine brake at all and would coast for a long time. In that case you could get the PCM reprogrammed by a dealer to change that. I thought they eliminated this after a lot of complaints but it might be an idea to ask a dealer about it. I cannot find anything in OASIS but there are things that are left out...
DAVID JIMENEZ2
  • 16 POSTS
If in park pressing and releasing the gas has normal effect on RPMs. The RPMs drop immediately like a normal car does. It's only happening when in forward gears (reverse is kinda fast too, though now that I think about it). I'll check on the way home today to see if there is a difference when I have it out of Overdrive.
STEVE W.
  • 15,113 POSTS
Yeah, I'm betting it's a software issue then. If it was just in the engine it wouldn't act "normal" in park. Been a while since I've driven one but I recall the earlier ones acting that way (and the thousands of complaints at the time). It was because of the emissions and fuel economy standards at the time.
DAVID JIMENEZ2
  • 16 POSTS
Steve, Is there something in particular that I can say to the mechanic at Ford to better explain what needs to be adjusted in the ECM when I take it in?
STEVE W.
  • 15,113 POSTS
Well there are a few things but being this is a family friendly place....
About the only thing I can suggest is to explain exactly what it's doing and mention the repairs you have done and that based on your research you came to them to see about an update to the programming. Would be a good idea to take the service writer or the technician for a ride to show them the issue.
DAVID JIMENEZ2
  • 16 POSTS
Thanks, will do. I will post the outcome for others to learn from...
STEVE W.
  • 15,113 POSTS
You're welcome.
Thank you for using 2CarPros.com.
Tell your friends, family and anyone you like about us and please return with any auto related questions, we're here to help.
MRAVERAGE
While moving about 30 mph, my Taurus will slowly accelerate to 50 mph with my foot off the gas pedal on a level road. This is annoying in traffic because I frequently have to hit the brakes to slow down, and then it creeps back up.
Out of curiosity, I was moving at 15 mph in an empty parking lot and then put the transmission in neutral. The RPM jumped to 3500 without touching the gas. The RPM dropped to 1200 after I hit the brake pedal hard. I repeated this with the same results.
What's the scoop?
Hi MrAverage, Welcome to carpros and TY for the donation
Clean out the idle air control valve and test the throttle position sensor, also clean the MAF sensor with an electronic cleaner CRC and see what happens-Double check if the throttle plate is closing completely carbon/varnish might be preventing from closing,also inspect the throttle linkages and accelerator cable if its kinked inside the sleeve-
MRAVERAGE
When the car comes to a full stop, the idle drops to normal. This would imply that neither the idle air control valve, TPS, MAF sensor nor the throttle linkage is involved. The idle will drop form 3500 to 1200 without the gas pedal moving.
As soon as the car is moving again (at as little as 10 mph), the process starts over again and the RPM climbs to 3500 in neutral (or the car accelerates when placed in drive). The RPM will only drop to idle at a full, dead stop.
Did you physically check and test the TPS and the MAF sensor?
LENREIS
Car starts and idles fine. When in drive, I get up to speed and release the gas peddle and the RPM's will not decrease. Car does eventually slow down, but only after miles of travel. I have actually traveled several miles at 45 miles an hour with no acceleration from me. Once I hit the brakes it will slow down, but it's almost like the gas peddle is always being pressed down a little, but only when I'm driving. If I'm stopped at a light, I will be idling at 800 rpms. But once I take my foot off the brake, RPMs will slowly climb up to 1500 rmps then shift into next gear...I haven't tried letting it go further than that. Although car was doing this already, I had a Check Engine Light with a code for the TPS, I replaced the TPS and reset code, light hasn't come back on yet.
Any clue?
Aug 21, 2020 at 1:57 PM (Merged)
RONRON61
I have the same problem but with a 1999 Taurus 3.0L
was told to replace the Idle Air Control Valve .... did but that did not help the problem. Next they tell me to replace the throttle position sensor.(have not tried that yet). if I place mine in neutral the RPM's go up
Has your check engine light come on? IF not, keep in mind these are all guesses. That is the first thing I would say is the TPS, but a lean mixture can even cause it. Check for vacuum leaks too.
Let us know what you find.
RONRON61
Joe Thank's for the reply
No the check engine light has not come on and replacing the TPS did not change anything :(
Can't hear any vacuum leak but have no other way to check (far from being a pro on my part).
Ron
Many people use starting fluid or carb cleaner and spray it around the vecuum hoses. If there is a leak, the engine will draw in the spray and the idle will increase.
One point I have to make. If you do this, be careful. If the starting fluid hits an exhaust manifold or other very hot area, it could catch fire. It sounds scary, but just be careful and have a fire extinguisher near by.
