2004 Ford Taurus hesitation when accelerating and stating
2004 FORD TAURUS
114,000 MILES • 6 CYL • FWD • AUTOMATIC
ROGERMONTERO
please help, i have a 2004 ford taurus when i start the car it acts like it wants to die, after a few minutes it fine however there is a big hesitation when going into second gear..... i'v replaced the throttle positioning sensor, plugs, wires and coil but problem is still there.....when replacing a throttle sensor does it need to be calibrated ?, if so how do i do this ...... do you think that this is the problem or is there another sensor i need to look at? thank you and god bless...
Apr 23, 2009 at 12:40 AM
BMRFIXIT
  • 19,053 POSTS
Do you have a check engine light on ?
and if so san for codes and let me knoe what you have for codes
I would suspect fuel pump
was fuel pressure checked
check for fuel pressure and volume
get a fuel sample and check for water
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
Apr 23, 2009 at 8:08 PM
