2004 Ford Taurus heat shield
2004 FORD TAURUS
65,000 MILES • 6 CYL • FWD • AUTOMATIC
PEPPERONE
  • 18 POSTS
just changed plugs & wires & while changing them i knocked off this hest shield does any body know where it goes.if any body can help me would be great . thank you.i am adding pictures of heat shield may be some one knows where it goes. came off while changing plugs in back near firewall
http://www.poten.com/dev/carpart.htm
Feb 28, 2008 at 7:12 AM
MERLIN2021
  • 17,250 POSTS
Looks like the heat shield for the a/c evap case...put the flat side to firewall tie on with wire or a good glue'...
https://www.2carpros.com/forum/automotive_pictures/62217_Evap_Shield_1.jpg
Feb 28, 2008 at 7:17 AM
PEPPERONE
  • 18 POSTS
no it is not for that. it is for heat sensor on transmission right below plug # 1
Mar 5, 2008 at 11:16 AM
DOGFISH345
  • 4 POSTS
Below #1 plug?
I see some type of sensor above #1 and #2 plug.
I do not see anywhere below where it might fit.
Does the intake manifold need to be removed to renstall it?
Thanks
Mar 7, 2015 at 6:57 PM
